bigbadchev84
I just recently swapped a 350/205 combo out of a used blazer i picked up. I got it into my blazer, replace the tranny kickdown, changed the filter new fluid and all is well.
BUT when i am at a stop and start to move if i get on it, (not even WOT just 3/4 pedal) while in first it revs high then starts to studder and shake the whole truck until i let off the gas and then it shifts fine.
If i keep my foot out of it, which 99% of the time i do it does great, nice smooth shifts no problems. Any ideas on what is causing it?
When i installed the kickdown cable, i opened the throttle to WOT and then pulled the cable tight and installed. is that the correct way?
this is the kick down i installed:
