I'm sure this is going to open a can of worms, but this is the first time in a long time of relocating sensors that I actually got real time real temp data.
I drove 18 miles at roughly 60 mph and the temp on the TH350 pan was no more than 150. On the way home at 75 to 80 mph temp was no more than 180 on the interstate. Pulled into Safeway for 15 min and temp dropped to 150. So I am saying to myself, is this that bad?
I am running the normal trans cooler in the radiator cooler plus a pancake cooler on the passenger fender. The pancake cooler is under the engine oil cooler which never got above 150 on the same trip and and has a fan that is thermo controlled at 190. Engine coolant temp never got above 110 coming out of the bottom of the radiator.
I have a 24" single pass tube cooler that I could mount easy enough before it enters the trans pan. I believe that I have lost my 2nd gear or the trans just shifts past 2nd due to too much pressure. Not sure.
Any help is greatly appreciated.
Joel
norcal
Joel
norcal
