th350 to 205 gasket
woodchk502
MI
Im having absolutely no luck finding the gasket that goes between the th350 adapter and the np205 (tcase input side)1972 jimmy napa, advance, autozone, even local chevy garage (their coputers wont let them look up anything older then 1982 :mad::mad:). I cant even come up with a part number. Can anyone help?? Im tired of my jimmy just sittin.
thanks jim
thanks will check tomorrow.. Thought about it initially but then started thinking that they would prolly unbolt tranny from the flange and have no need to carry the one i need. But I will leave no stone uncovered.
thanks jim
I was just looking for some t-case gaskets also and the local tranny shop did have a bunch. Surprisingly they had the t-case side but not the tranny side of the adapter. I ended up having to cut one on my own though so that is an option also. Parts store should have the material.
Bigbadchev was correct local tranny shop had one $4.
Igor thanks if this turns out to be the wrong one I might take you up on it. Othrwise maybe another member can use your generosity.
Thanks guys the members on this site make it what it is..... The best
Trans to t-case adapter doesn't use a "gasket" it uses an O-ring.
I shouldn't have included that phrase because I am running a sm465 and did not know the th350 uses an o-ring. Whoops!
