TH350 to Crate
caleb22
South Carolina
Looking at a Blueprint crate 350 as a starting point for my '76 with a TH350. I have 35's and a 4" lift now and the stock 350 needs a rebuild bad. I'm going to leave it in there for now so I can still drive it but get a crate as a base to start from. Then put my K5 engine in my Jeep after a rebuild.
https://blueprintengines.com/collec...s/gm-350-with-vortec-heads-roller-cam-1pc-rms
Don't know if anyone can recommend anything different but need to keep costs down and since I have limited/novice engine experience I need a solid base to start with. This will be for a DD and no wheeling or anything.
check summit, jeggs and speedway..for that motor..they run sales on those long blocks
You can get an L31 crate motor from GM for ~$1800.
The blueprint must have modified heads to accommodate the lift, and it makes 40+HP over the L31, so extra cost is valid, but as I found when looking at all these things, all the aftermarket engines have downsides I didn't see with the L31. Or at least things I looked at as downsides...overbores, etc. The cost to make more power is exponential, not linear. I actually did a spreadsheet to see what the $ to HP ratio was, and I'm pretty sure the L31 beat out everything I compared it to.
Heads, valve covers, timing chain, oil pan, cam, gasket set, etc.
You'd be into a crate GM roller cam engine for $800 more, without needing any of the above.
I know, broken record, but I just don't see the savings unless you are going to go wild on the cam.
TH350 will bolt to any SBC.
