398HBX
I did a quick search on the forum but could not find what I was looking for. Mainly advice from people who have "been there, done that". I'm hoping that you guys can help. I am rebuilding my father-in-laws (Stan)73 K5. I am using an 86 K20 Burb as a donor. I would like to use the NP208 out of the K20 instead of the NP203 out of the K5. I have a new B&M TH350 for the K5. The K20 has a TH400HD/NP208 combo. I am swapping the axles from the K20 to the K5. I would like to have kept the TH400/208 Combo intact but Stan made a valid point: why put a 26 year old transmission with over 100k miles on it instead of a new B&MTH350 Competition?
Here are my questions:
1. Where can I buy and adapter kit to connect the TH350 to the NP208? Other than Advance Adapters (Expensive).
2. Would I use the W crss member out of the K20?
3. Will the frame cross member bolt up to the same frame holes?
I could use the NP203 with a part-time kit but then I will have to change output shafts to match up with my 14BSF rear axle and 10 bolt front axle. I think?
Any help is greatly appreciated.
