Moody
After much debating on which transmission to use in my 70 Blazer I have to decided to use a SM465/205/203 combo to go behind the 406 I have had built. I have found a complete 465/205 setup with bellhousing, linkages, etc. I know I will need the obvious stuff....flywheel, pressure plate, ect. I am assuming the pedals will be different as it is out of a 76 blazer. Anything else I should look for to complete the swap?
