88bigburb
Registered Member
ok guys, i know i dont contribute a whole lot here, but i definitely appreciate the info i can find. and now i have a couple more questions. I'm basically looking for any pointers on things i missed as far as this swap goes, and a couple other questions. i'll try to lay out as much info as i have and hopefully not miss anything.
Vehicle: 1975 Blazer, 350/th350/np203, D44 front, 12 bolt rear.
the 400 i have to install is from a 79 burb, it is coupled to a 203 as well.
1. Unbolt and remove th350/203, either as one or in 2 pieces,
2. mount up th400/203, and relocate crossmember.
3. Reattach shift linkage-the one i have should work right?
4. Reattach cooler lines-can i reuse the stock ones?
5. speedo cable-should be the same attachment right?
6. Measure new rear driveshaft length.
7. After getting driveshaft shortened re-install.
I have a "new" front driveshaft, that came from a 1-ton with a th400/203
will that work to attach to the 44 front, or will it be too short? and will i need a conversion u-joint? if so part numbers would be great.
I have the stock rear driveshaft from the 75 on it still, should i get that cut down, pretty sure its aluminum, and i have driveshafts from a 70 f-250 that i believe to be steel i'll take a magnet to it on my lunch to check, should i have that cut down instead... assuming the yokes are the same.
do i need to get the new driveshaft balanced? or should it be alright without.
alrighty, i think that just about covers it, thanks in advance,
Ps. i'll repost on the material of the driveshafts later
