TH350 - ??What gear is it??
Greg72
@MIGHTASWELLK5
Staff member
Super Moderator
Austin, TX
I'll admit, I'm a little lost here. I was trying to calculate some basic stuff on engine RPMs and Tire Diameters, and pretty much the first thing you need for the formulas is the gear ratio. That should be the combination of the (individual gear ratio X rear end gear).
I know I have a stock TH350 tranny, and I have 3.73 gears....What I don't know is, what are the stock gears in that transmission? Anybody know? I have a few documents with basic K5 dimensions and capacities, but nothing on the gear ratios.
Thanks,
-Greg72
Not sure what yor after but most rpm tire ratio formulas look for final drive which is 1:1 in a th350. But you have to factor in a few hundred rpm for converter slippage too.
I guess I'm comparing it to manual transmissions which is my only area of familiarity
Suppose you have a transmission with the following gears:
1st 3.08:1
2nd 2.45:1
3rd 1.48:1
4th 1.14:1
5th .89:1
And a rear end ratio of 4.10:1
To calculate a MPH, you need to multiply the individual gear ratio by the final drive to get a "mulitplication factor"
ex. 3rd Gear (1.48) x Rear End Ratio (4.10) = Multiplication Factor of 6.068.....that's the number that gets plugged into the formulas for MPH or RPM, etc.
(NOTE: All the ratios in the example are made up. I'm not trying to say those are actual ones for any K5) ;^)
If this make sense to anyone.....and you can help bridge the "gap" in my knowledge please jump in here!
Thanks again,
-Greg72
The gearing on the TH350 is: 1st:2.52, 2nd:1.52 and 3rd:1.00. By the way, if you are comparing w/ a 700R4, those ratios are 1st:3.06, 2nd:1.62,3rd:1.00 and OD:0.70.
Here is a link to Randy’s Ring & Pinion on-line calculators: <A target="_blank" HREF=http://www.ring-pinion.com/RPMCalculator.html>http://www.ring-pinion.com/RPMCalculator.html</A>
AWESOME!! That's exactly what I was looking for!
Thanks to you 71RestoRod!
-Greg72
Or if you're like me and doing a 4L80-E swap the ratios are:
1st: 2.482
2nd: 1.482
3rd: 1.1
4th: 0.75
