th350np205 combo bracing and strengthening
mudhog
THEGAME
portland oregon
so i might be building an 80 blazer that has a th350 np205 combo in it. what have you guys done to brace the tranny and transfercase to make them stronger.
I dont run any bracing system on mine. (th400/205). Never have, never needed it. I just make sure my bolts are tight, and use poly mounts and make sure they stay real tight.
i just want to keep the thing from twisting and snapping the tranny in half like i have seen done
iv got buddies running scs drop boxes in 2.5 ton mud trucks behind 350s and 400s and theirs don't have a problem. if the case is gonna break then theres not much bracing will do. keep in mind autos are made out of aluminum. best way to prevent a case failure and its probably not a option for your build is a 465 with an aftermarket steel bellhousing. that's what my rig has after I cracked a stock cast bellhousing on the trail
i just changed from a sm465np205 combo lol although i still have the setup just not the blazer lol i want to go with a auto this time. id rather go with a th400 but this one came with a th350 so for now thats what i will be running.
