th400 2wd to 4wd
rok-1
Newbie
kansas
I have 4 speed standard bolted to a np205. How hard is it to convert automatic th400 from 2wd to 4wd can anyone help. Thanks
If you have a 400 with a short tailshaft it's pretty easy. The tough part is the t-case. Assuming you have a short tail trans, check to see how far the shaft sticks out of the case. If it's about 4.5" then you're real good.
The rest of the story...
I'm assuming you want to use a 205 since you have one now. You'll need the correct adapter to bolt the trans to t-case. Next you'll need a short 32 pline input shaft for the 205. It's easiest if you can find an original 32 spline 205 t-case otherwise you'll need to bore the case to accept a larger bearing (that goes on the input shaft).
It can get confusing quick. If you're not already familiar with the different variations of the GM 205 you might want to spend a little time on ORD's site reading before you go any further.
There is also a super good 205 tech thread in the Chevy section on Pirate4x4.com
I believe you have to first find out what input your transfer case has, then get the matching output shaft for your 400, then the adapter to put between them.
This would require complete disassembly of the trans.
Do you know if your 4spd/205 is 10 spline or 32 spline?
