th400 4wd, SM465 4wd 32 spline, Sac CA
imiceman44
Hoarder extraordinaire
Lincoln, CA
Th400 4wd $250 (w/adapter) $200 w/o
Sm465 32 spline $150
TC cover $25
bp71k5 said:
Still have the sm465? What's the condition? What kind of x-case was it mounted to?
Still have the 32 spline 465.
Good condition.
Was bolted to a 208.
It's the same as the one bolted to a 205, just different adapter.
Sold the one with the 205:D
Dang, I think I need one that was bolted to a 203 for a doubler conversion. Although, I might be able to find an adaptor separately. Do you have any leads on one in your area?
The 203 version is like any 205 version, it's a 10 spline ouput, you can find them any day.
The adapter on the other hand is going to be your problem, finding one of the few made for only 1 year ever will be a trick.
Yea, I'm getting the feeling this might be a dead end or even more expensive than I thought. I have a lead on an adaptor and if it works out, I'll take your 465 if it's still there. I'll know in about 3 days.
I have a 10 spline 203 and adaptor for a sm465 on the way. Did you say the 465 has the 10spline output or the 32 spline? (The first reply says 32, but the one after says 10 spline?) Sorry if I'm confused.
No , mine is 32 spline, I said in my second post that you setup requires the 10 spline which is very common, and you should be able to get one cheap.
