th400 dip stick tube removal
there is one tab that bolts to a bellhousing bolt, its the upper one on the pass side, then just pull it out. /forums/images/graemlins/waytogo.gif
they are a real PITA to get out, theres a tight rubber seal holding them into the tranny. When i removed one...i had to twist pull, twist pull, twist...repeat til its out.
