Kenny78
Ok, so I my TH400 in a K20, slams into gear hard from park. I have checked for a vacuum leak from the brake booster, none. The tranny shifts fine when driving. It does have a small leak (in the process of fixing it) but I have checked the fluid before driving which is very little since I just brought the truck Tuesday. I was reading something about check balls being in the incorrect position but IDK. Any ideas?
Thanks in advance
Thanks in advance
but will tomorrow. This truck is the first truck in the fleet without glasspacks so it is deceptively quiet
I hooked my vac. gauge inline with the modulator line(which is hooked to manifold tee behind the carb.
