Th400 kickdown switch picture
wage92
Upstate New York
Interested in seeing a picture of how the th400 kickdown is mounted to gas pedal, not sure my pedal will work...? :dunno:
it sets on and held by a screw / bolt. if your gas pedal bracket has the tab on it.
and then any gas pedal will hit the switch as there bend the same . its just if the top plate with 3 bolts that holds it all to the firewall is there with the switch .
i think i figured it out and its what you are trying to explain so i think im got it right. thanks
awesome, thats how i did mine. And one wire off that gets hot, the other goes the terminal on the trans?
