Th400 not pumping fluid
down4thakrown
flagstaff,az
So I'm bout to move my k5 for the first time and nothing. Pulled the lines, not pumping fluid. Pulled bolts out of t/c and spun it, doesnt drop a notch or fall into anything. There is a little gap, but it doesn't move in and out of pump slot at all. Anything else I can check b4 I pull it.....:mad:
Turns out was the gap. It was barely catching b4 were it would probably let loose once it starts
