I just spend a couple hours searching old threads and couldn't find an answer to my issue, so hoping someone can help.
Truck is a 73' K5, 350/TH350/NP203. I finished pulling my TH350/NP203 out and putting in a TH400/NP205 (figure 8 adapter) tonight. Problem is the cross member for the trans/t-case that locals say should work is causing the 205 to hit the bottom of my cab. Cross member has about a 1" drop and has a relief for the front drive shaft (was told it came out of a K20 suburban, not sure on year). Looks like I need to be at least 2" lower than it is, does this sound right to anyone? Is the 73" K5 different from others?
My 203 cross member has about a 3" drop to it, but no relief for the front drive shaft. I don't mind cutting it, but want to be sure my output angles are ok, how can I tell if they are off? Does the trans pan need to be somewhat level?
Thanks for any help!
For now I built a couple quick 1 inch spacers just so I could bolt it up and get driveline lengths meaured.
