Th400-np205
GreenieK30
Washington
This is the best TH400/NP205 offered from the factory. The TH400 deep pan transmission is a 1988 4x4 case with the extra thick casting bellhousing and tailshaft areas. It also has the newer locking o-ring dipstick tube. The NP205 is a 1988 round pattern, big bearing 32 spline input, 1350 u-bolt rear yoke, 30 spline front driveline output shaft and latest design shifter with the greaseable rubber bushing and shift pattern on the knob. It also comes with the dash indicator light switch, crossmember, torque converter, cast cover and front driveline.
$700
By Tacoma, WA
