Th400 pickup tube
Smokinthehippies
3/4 ton status
Millard, NE
Anyone know where I can get a pickup tube that goes between the filter and pump. I have the deep version (which is about 7") I need the shallow version (about 4 3/4" long)
I realize this should probably be a wanted and but I just new a link more than anything. The only ones I've found have been for the deep versions
Thank you!
I bet my buddy who owns a transmission shop has what you need. Give Mark a call at Mark's Transmissions here in Fremont, 510-790-3322 and tell him I sent you.
Sweet. I'll give him a shout on Monday. Thanks Scott!
if that doesn't work, I have a th400 broken case that I will be parting, I could get you that part. My pan is the standard pan not the deep pan so I am assuming it's the one you need right?
