Thanks in advance for helping. We put a used 400/203 combo in my dad's '72 back in 1992. It has worked very well until the past few years. It got retired to a hunting truck about 6yrs. ago so it seems to only get used for 2 weeks every november. The problem is that first thing in the A.M. the trans seems to fails to upshift to second after releasing first. He found out that if he shifts it manually back down to first, it will then upshift to second. After that all is well. He doesn't want to pull the trans for a rebuild because he's 73 and doesn't think the truck is worth the money. I am having a hard time with the thought of helping him install a used TH350 from a friend of his. At the same time, I am not confident in my own skills to fix the problem even if we did a complete build. Does anyone have some insight for this problem? My thoughts are weak seal ring on 2nd that are helped by manual shifting? He has checked the S-link at the valvebody and thinks it is okay.
