TH400 question
b454rat
Binghamton NY
OK so I can't access the 400 output page anymore.:mad1:
I'm trying to figure out what t-cases will bolt up to a 2wd I have. I believe it's the longer one, 4 1/2" or something like that. I have no t-cases or any adapters, so I need to find one for whatever case. Possibly going with a Ford case, so need adapter for that as well, which I think is the 208/241 version with some mods....
Years ago I did this, to the very tranny I have now. But, sold everything but the tranny. Ford case with IIRC short input, custom spacer and 208/241 adapter....
Could go with div 205, but then it's back to fab'n stuff that I really don't want to get into...
Ok need to change from using a Ford case to just GM case. I forgot that I have a GM 60....
But got the sheet from Woodchuck (thanks!!) looks like what I have is the 9 1/4" long, which is the same as the short 205 input, which IIRC is the 8 track style.
So, I have a 465 with the 205 in my truck now, in order to use this case I would need short input, 8 track adaptor, and open up the case for the bigger bearing??
attachment.php
