My brother in law just had his th400 rebuilt in a 79 3/4 ton and now it slips between gears.
When you put the truck in gear from say park or neutral it shifts into gear good and runs good, no slipping, until it shifts gears. When it shift from 1st to 2nd and from 2nd to 3rd its like it goes into neutral. If you let of the gas for just a second and then get back on it, it will go just fine, no slipping.
Reverse also works just fine, no problems. You can also hold it in gear and as long as you keep it in that gear it doesnt ever slip. It will only slip when shifting between gears.
Any ideas on what it could be? My guess was the vaccum modulator and I told him to replace it when he got a chance but my knowledge of automatics is lacking so I hope someone can help. Thanks.
