this is a pic of the old 700r4 to th350 swap kits . the big aluminum spacer took up the difference .
i am in need of a spacer for a th400 with male on 1 side and the female on the other side . just a straight up spacer . this would be 1" - 1 1/8" thick range .
i have a combo i need to bolt up but cant just use a re-drilled round pattern adapter on it . so the spacer would be fast / easy / work good. and i dont want to tear apart the good working trans just to change a tail shaft and i dont have the tail shaft i would need anyway .
