Made it 100 miles, now my trans slips in every gear. Wont hardly move and when it does it slams into gear. And does it very fast on and off. Is it something that could be fixed road side? Filter,valve body loose?
Fixed it, not sure if torque converter bolts got a little loose and flex plate pulled t/c off pump or what but I added a thick washer between the t/c and fly wheel and it was good again. Or it just got hot and by time I put the washer in it cooled down enoughMade it 100 miles, now my trans slips in every gear. Wont hardly move and when it does it slams into gear. And does it very fast on and off. Is it something that could be fixed road side? Filter,valve body loose?
I seen this one other time my buddy josh got a short bed that had a rebuilt trans in it for a POS of a truck in trade. Guy put a trans in the short bed and it did the same thing. Pulled it and had it rebuilt and it did the same thing afterwards. Trans guy said to pull it back out but he didn't want to so took a huge loss and traded my friend. Anyways my friend did exactly what you did and drove it for a few years before selling itIn all gears, even reverse. But it ran good the rest of the way after, going 50-60mph for almost hours
But now it won't move at all. Tried loosening bolts and spinning t/c but no luck. Doesn't do anything or feel like it goes into gear. I'm going to pull the pan and check filter and valve body. Is it possible the pump moves back? Or sheer the teeth/notches on pump or t/c? I've been hammering on it since the trip and driving it hard... No matter what I pretty sure its getting pulled and built...by a reputable trans shop with goodies
