It's fun to point out that the smaller transmission has a 23% lower first gear, so it's "designed" to put 1% more torque to the wheels![]()
Hahahaha!
Basically the 700r4 before 1987 were like experiment transmissions until everything got right after 1987.
Today , a 700r4 with today's technology can be built to withstand 500 to 600 horspower from a 454. Just not way above that if you want to do drag racing
I just don't get why GM didn't make the 700r4 better out the gate . While Ford done note bad on their transmission.Not experimental, they made millions of them. They have progressively strengthened various components. Some upgrades are backwards-compatible. My built 1983 700R4 is likely to last longer than the tranny it replaced, assuming the rebuild shop did a good job. Because they put in better parts than they took out. But it's still a marginally-better 700R4, no matter what parts you throw at it.
Say what?I just don't get why GM didn't make the 700r4 better out the gate . While Ford done note bad on their transmission.
I mean was it that difficult to make a strong 4 speed transmission, compared to the turbo 400, to help with fuel savings if not by a lot?
Ive been thinking of today of putting a 480Le transmission with the carburated 454 my Suburban has, that is c20. Along with other light modifications to help with a little mpg.No, it wasn't hard. And when GM felt the need, they did so, with the 1991 introduction of the 4L80. That's exactly what you mentioned, a 4 speed comparable to the TH400, with some fuel savings.
