th400's AND np205's , TH350
YZEATER
TARENTUM, PA
http://s130.photobucket.com/albums/p276/YZEATER/stuff%20for%20sale/
th400 $50 had a np 205 behind it, no adapter
np205, from behind a th350, no adapter slip yoke, apart - $100
th400 -np205 NO adapter. slip yoke, figure 8 pattern. bell housing is cracked
on th400 but will mix and match with another th400. $150
th400 had a figure 8 pattern 205 behind it $50
TH350 had a NP203, no adapter $100. WORKS VERY WELL.
th400 . had a round pattern 205 behind it. $100
can try and ship some of this, just understand it's going to be expensive, around $100, maybe more per piece (tranny or t-case) . this stuff needs to go, would hate to scrap it.
offers??
other stuff, ask.
added stuff, will split up adapters or whatever. gonna start going for scrap soon.
np 203 and adapter from behind the th350 and the 205 from a th400 is sold. thnaks patt107
adapter and np205 from behind a th350. $150
Will you sell the adapter?? If so, PM me with details to 39208.
first you ask about one from a th400, now your asking about a sm465 one. which is it???
th400 had both round and figure 8 adapters, and 465's had both round(newer) and figure 8 style (older).
i want to build a doubler and from the information i gathered i need a 205 from behind a th400 because it is the 32 spline unit. i have a 465 in my truck that is from a 1980 but i was told its a 10 spline output. if my thinking is correct i need to change the output shaft to a 32 spline like from ord, then i need a 465/203 adapter, a 32 spline 203 rangebox, and a 205 from a th400
well, i only have figure 8 205's left. you'll have to find out if that's what you need. i will also lower the prices on some of that stuff above.
