YZEATER
th400, had a 205 behind it, no adapter. unknown condition, guy said it was good, i never tried it. $100
np205 for a th350. never tried it, turns freely. HAS SLIP YOKE, TRADED FOR A FIXED YOKE. NO ADAPTER. not together $200
th400 and np203. out of a running truck, both work fine. $300. removed from the truck, found out one bolt hole for the mounting to the crossmember is striped. can be fixed with a drill and tap or use a nut on the topside.
208 to th350 adapter only $50
ford c6 auto $50 , unknown condition.
OBO ON EVERYTHING, trades accepted also.
located near pittsburgh Pa.
will separate adapters from t-cases/ trannys.
