TH700- Oil change
Ralph the german
Registered Member
Germany
Hi fellows,
to be secure, please tell me, can I take a Dexron II synthetic fluid or not a synthetic for the TH700. I read a quantity of 10 pts. = 4,73 L. Is this correct ?
Ralph
you can use synthetic if you'd like...but if you do change to synthetic you should flush out all of the non syn type fluid. 10 pints would only be a oil and filter change quantity. The trans holds up to 24 pints when its dry (rebuilt).
