Th700r4 oil, in transfer!!
Mikedohc
Registered Member
Dear friends, I am writing to you from Spain! I have already finished testauring the th700r4 change and mounted the transfer, everything works fine, but I have a problem, I could see that the transfer retainer where the transmission is, leaks oil. and the problem is that the oil from the th700r4 automatic gearbox is passed to the transfer new process. I don't know where it is going and if there is a meeting to be changed, do you know of any such cases? What joint should I change? I hope comments thank you very much!
There is a seal in the back of the th700 case that is to keep the oil in the trans. This seal may be missing or damaged
my question is, does the th700r4 have a seal? Or is the transfer the one with the seal so they don't mix? When I assembled the gearbox and attached it to the transfer, the box did not have any seals, its last part of the box is the governor, and it is filled with oil, from what I understood, that the seal must be in the transfer
T case input seal.
There is a square cut o-ring that goes on the back of the trans to the adapter.
That’s correct. The back of the transmission is open. There should be a seal on the input of the transfer case.
ok thank you very much, then i will change the transfer seal, and the transfer cover gasket.
I understand that the th700r4 box is open, it does not have anything on the transfer that closes its oil.
Can you give me the references to buy it at rockauto !! ??
thank you
Ir you can tell me une dimensión for a señal i Need, i can bit it and hace ir when i disassemble y he seal and put it at TGSS moment!! Thanks for all
I think is it: 49.230 x 12.700 x 68.200. and reference 710928 its ok???
