That's a lot of typing for a $10.00 part. Look at this CL post.
That guy deserves a medal for having quite simply probably the most informative Craigslist as in existence. Most people you'll be lucky if you can get an item name and a price
Dear lord almighty! Id be amazed to see him post an add on something thats complicated!:eek1:
posteriquote!
Blackhawk Automotive Body Repair Frame Pull Clamp Excellent Condition - $10 (Bakersfield) Date: 2012-09-20, 11:03AM PDT
Reply to: see below
I am selling a Blackhawk Automotive Body Repair Frame Pull Clamp with original Bolts, Washers, and Nuts that my father bought brand new and used while he was working as an automotive technician. My father passed away and I am selling off some of his tools which this clamp is from. The clamp can be used for automotive body or frame repair. The clamp is made from steel, it has 2 pieces to it, 1 piece on the top and 1 piece on the bottom and it also has 2 original clamp bolts, nuts, and washers that are included. The top piece on the outside is in the shape of a T from the top with the long width end of the T curved at the top towards the metal teeth or jaw of the clamp. The outside top piece of the clamp has 3 U shaped steel lines on it for reinforcement to the clamp and 2 U shaped lines on the outside serve as locks to lock the bolt heads against the lines when removing or tightening the nuts of the bolts on the other side of the clamp; the middle of the wide portion of the T has an approximate 5/8" hole drilled through it from the factory with the ends of the T having an approximate ¾" hole drilled through them for a total of 3 holes, but only the ¾" holes are for the clamp bolts to fit through. The outside top piece of the clamp has "BLACKHAWK" and above that word there is "PULL" stamped on it in red metal lettering. The outside top piece of the clamp also has a cross stamped on it above "PULL" in red metal. The bottom of the T of the outside top piece of the clamp curves slightly down to meet the bottom piece of the clamp. The rear of the top piece of the clamp is also in the shape of a T just like on the outside. The rear of the top piece of the clamp has small steel teeth going across the wide portion of the T with the teeth being in the shape of small triangular squares for an approximate width of ½" from the very top of the T down. The rear of the top piece of the clamp also has the 5/8" diameter hole in the middle with the ¾" diameter holes on the ends of the wide portion of the T. The rear bottom of the T of the top piece of the clamp curves slightly inwards with the bottom being flat with an approximate width of ¾" up from the bottom of the T. The ¾" wide flat portion on the bottom of the T on the rear of the top piece of the clamp has a partially drilled hole in the exact middle that has an approximate diameter of 7/16" from the factory. The outside and rear of the top piece of the clamp is painted red and the top piece of the clamp has no cracks, nicks, dirt, marks, rust, or discoloration, in good condition. The circumferences of the 5/8" and the two ¾" diameter holes on the top piece of the clamp have no cracks, dirt, nicks, marks, rust, or discoloration, in good condition. The small steel teeth on the rear of the top piece of the clamp have no rounding out, cracks, nicks, marks, rust, dirt, or discoloration, none of the teeth are broken or missing, in good condition. The partially drilled 7/16" hole on the rear bottom of the top piece of the clamp has no cracks, nicks, marks, dirt, rust, or discoloration, in good condition. The bottom piece of the clamp is also made from steel, it is painted red on the outside and rear, and it is in the shape of a T with an approximate ¾" diameter hole drilled through the wide ends of the T for the clamp bolts to fit through. The outside of the bottom piece of the clamp has a round U shaped steel rod welded to the top of the T to be used to be hooked onto a hook or chain for the clamp to be used to pull on an automotive body or frame. The round U shaped steel rod welded to the top of the T on the outside bottom of the clamp is painted red, it is smooth steel while the rest of the clamp is slightly rough steel, and the U shaped steel rod has an approximate outside length of 3 ¾" from the outside of the bottom clamp piece to the outside of the U shaped steel rod with an approximate inside length of 3 ¼" from the outside of the bottom clamp piece to the inside of the U shaped steel rod. The round U shaped steel rod welded to the top of the T on the outside bottom of the clamp has an approximate outside width of 2 ¾" with an approximate inside width of 1 ½". The round U shaped steel rod welded to the top of the T on the outside bottom of the clamp has "BLA97183" printed on it in black marker with the lettering having no fading; the U shaped steel rod has no cracks, nicks, or rust, no loose welds, in good condition. The outside of the bottom piece of the clamp has "1.8" stamped on it near the bottom of the T in red lettering. The outside of the bottom piece of the clamp rounds down on the bottom of the T. The rear of the bottom piece of the clamp is in the shape of a T with the top of the T being round upwards for the small steel teeth, it has the ¾" diameter holes, 1 hole per side on the wide end of the T, with the very bottom of the T being flat. The small steel teeth on the rear of the bottom piece of the clamp have an approximate width of ½" with the teeth painted red and in the shape of small triangular squares, the teeth have no cracks, nicks, marks, rust, and no teeth are rounded out, broken, or missing, in good condition. The rear bottom piece of the clamp has a small rectangle engraved in it near the bottom of the T with "K5" stamped inside the rectangle in red lettering. The bottom of the T on the rear bottom piece of the clamp is flat for an approximate width of ¾" with a small round steel protrusion in the exact middle of the ¾" wide flat portion that has an approximate diameter of ¼" that fits inside of the 7/16" partially drilled hole on the rear of the top piece of the clamp when the clamp is bolted tightly together. The ¾" flat portion and ¼" protrusion on the rear of the bottom piece of the clamp have no cracks, nicks, dirt spots, marks, rust, or discoloration, in good condition. The two ¾" diameter holes on the outside and rear of the bottom piece of the clamp have no cracks, nicks, scratches, marks, or rust on the circumferences, in good condition. The outside top and rear of the bottom piece of the clamp has no cracks, nicks, marks, rust, or discoloration, in good condition. When the 2 halves, the top and bottom pieces of the clamp are put together with the original bolts, washers, and nuts, the 2 halves sit directly on top of each other with the small round ¼" protrusion on the rear bottom piece of the clamp fitting into the 7/16" partially drilled hole on the rear of the top piece, the clamp is in excellent condition. The 2 original bolts that are included with the clamp are both made from black metal, the bolt heads are hexagonal or six-sided with a wrench size of 15/16" or 24mm. The 2 original bolts are threaded from the very bottom up for an approximate length of 1 11/16" to where the bolts are round metal for an approximate length of 1 ½" to the bottom of the bolt heads with the bolt heads having an approximate width of 7/16". The very top of the 2 bolt heads have metal circles on the very top of them with 3 metal lines stamped inside the outer metal circle with another small metal circle stamped in the very middle of the bolt heads with a symbol stamped inside the very middle small metal circle. The very bottom of the 2 bolts are round black metal that is slightly indented going towards the middle of the bolts. The 2 bolts have no rounding out or cross threading on the threads, the threads have no cracks or rust, the 2 nuts easily turn on the bolt threads, the threads are in good condition. The bolt heads on the 2 bolts have no rounding out, the 2 bolt heads have no cracks, marks, or rust, in good condition. The very bottom of the 2 bolts with the rest of the bolts have no cracks, marks, or rust, the 2 bolts are in good condition. The 2 original washers that are included with the clamp are made from black metal with an approximate outside diameter of 1 3/8" with an inside approximate diameter of 5/8". The 2 washers have no cracks, nicks, bends, marks, or rust, in good condition. The 2 original nuts that are included with the bolts, washers, and clamp are made from black metal, they are hexagonal or six-sided with a wrench size of 1 1/16" or 27mm. The 2 nuts have a threaded hole in the middle with the threads being shiny metal and having no cross threading, rounding out, cracks, nicks, or rust, in good condition. The 2 nuts both have "2H, E" stamped on the top of them in black metal lettering. The 2 nuts have no cracks, nicks, marks, or rust, in good condition. The Blackhawk Automotive Body Repair Frame Pull Clamp with Original Bolts, Washers, and Nuts is in overall good useable condition, it looks hardly used, ready to pull on some frames on automobiles or vehicles. If you are interested in the Blackhawk Automotive Body Repair Frame Pull Clamp you can contact me on my cell telephone at xxxxxxxxxx, the clamp is for sale for $10.00, and the clamp is located in Bakersfield.
