So.....
I had this brilliant idea to finally move the '72K5 into the ManSpace tonight.
Got everything cleaned up really nice in the garage, and put a fresh battery in the truck to get it started. Pulled it from the side yard onto the driveway, and decided to give her a quick rinse with the hose to wash off the dust, spiders, etc.
Well something didn't go quite right.
As the engine was running, the hose shot over into the battery area (no inner fenderwells, remember?) and in an instant the engine completely DIES! Not like a stumble, just flat out dies INSTANTLY. Tried re-cranking it, but it doesn't seem to have any spark....I can definitely smell fuel after cranking a while. Definitely seems electrical.
Two immediate things I notice:
1. Small molded fuse holder (original) from battery. Pull it apart to check the glass fuse inside....all corroded. Cut it out and spliced the wire together with a promise to replace the fuse later. Still won't start.
2. The opposite side near the core support has a small 4-wire plug which I think has to do with the alternator charging wires (blue / white) and a couple others (Replaces the 4 original regulator connections). Pull the cover off that one, and it's all green and corroded, the two center connectors break off. I tried to jam some thin metal in there to re-establish electrical connectivity, but the truck still won't start.
Pulled a tarp over the whole mess and left it blocking the whole driveway. I guess I'll have to deal with it some other time. There's NO way I can push it into the garage stall to repair it there....too much tire and not much air in them.
Any ideas besides replacing the obvious defective items above????
Guess it's time to get intimately familiar with the wiring schematic again....
