The 67-72 One Ton Brake Booster Swap Guide ***PICS***
AJs72K5
blub-blub-blub-blub
Central Tx
On these old rigs we all could use some better brake power. It doesn't matter how much horsepower and torque you put to the ground if you can't stop the truck. To upgrade the brakes on one of these rigs you have a couple of options: hydroboost or a 1 ton vacuum booster. The one ton booster was supposed to be an easy swap, so that's the direction I took.
I picked up a 1 ton booster and master cylinder combo from the local auto parts store. The most cost effective (cheap) was a Cardone model 50-1007....basically a rebuilt Delco Moraine. I wanted to make the swap as painless as possible, so I went with the booster and master cylinder combo. If you choose to go with a different brand, you'll need to get one for a 1971 or 1972 Chevy K20 or K30...other models, including GMC, will work, but that's the easiest to remember.
Once you've got your new-to-you booster, the next order of business is to remove your the old booster. Here's my old one (left) next to the new 1 ton (right). The differences are pretty easy to spot.
It appeared that the previous owner of my rig put a pre-1971 (drum/drum) booster on my 1972 K5. It's no wonder my brakes were lousy after swapping in a 14FF rear with discs.
Here you can see the difference in the lengths of the input rods. The pre-1971 being about 3.25"
The length of the input rod on the 1972 1 ton booster is about 5.5"
If you have a 1971 or 1972 1/2 ton booster your input rod will be the same length as the 1 ton. Your swap will be easy as you already have the correct bracket mounted to the firewall. It'll look like this:
If you were fortunate enough to have a 1971-1972 bracket already bolted up to your firewall, you can skip to bolting up the new booster.
However, if you have pre-1971 booster with the short input rod, your firewall bracket will look very similar, but be about 1.75" shorter.
This picture has a better measurement on the pre-1971 as I wasn't flush to the firewall in the picture above :doah:
The pre-1971 bracket will need to be removed. I took mine off and headed to the local salvage yard in search of a 1971-1972 bracket. The two side plates are the pieces you're really concerned with. The center brake pedal lever pieces with the pins can be reused. Here you can really see the difference in the size of the two (71-72 on the left and pre-71 on the right):
Once you find them, get 'em cleaned up and painted and start reassembling the brackets. Here's pre-1970 with the center pieces:
And the 1971-1972 assembled reusing the pre-1971 center section:
BOLTING IT ALL UP. Slide the bracket onto the studs on the firewall and run the nuts on, but leave them out about 1/4". This will give you some play to hook up the brake pedal rod and later the booster itself. After attaching the pedal rod, push the bracket and lever up against the firewall check to make sure your brake pedal hasn't come forward and turned on your brake lights. You may have to adjust the throw so that your brake light relay isn't tripped (I got everything together before realizing this and had to tear it all back apart). Assuming your pedal throw is good, line up the studs on the booster with the bracket and slide it on. Run the nuts for the booster on and leave them out about 1/4" like the bracket nuts. This will give you a little play to hook up the booster rod to the brake pedal lever on the bracket. Once you've done that, tighten the nuts for the booster and then tighten the nuts holding the bracket to the firewall. Last step: hook up the vacuum hose...it's not much of a vacuum booster without one!
Voila!!!
Keep in mind that if you do go with the 1 ton master cylinder as well, that the brake line outputs are backwards from a 1/2 ton. The rear brake resevoir is in the front of the master and the front brake resevoir is in the back of the master. Bench bleed your new master cylinder, hook up your lines, bleed the whole system and you'll be ready to lock up some tires.
Great write up! You beat me to the punch with the pics. Mine MC/booster must have been changed in the past cause I just compared my brackets I pulled off my 70 and they are identical to the 71-72 one you have shown. Thanks!
I would like to add a comment:
My 72 came with two support rods connected to the booster/master setup. The pic above you may have to stare at for a bit to see them.
Look to the right of the P-valve, you can see the bracket/arm turn down then towards the firewall then bolting to the firewall, I had to add a round spacer when I switched from 1/2 to 1ton to reach the firewall.
The second brace is a rod that connects to the back of the booster to the firewall. You can see it infront of my green clutch master cylinder.
Anyway just wanted to point out that you may need extra support or bracing. I would assume it is to prevent flexing during hard brakeing??
.02c
Burt
Great post!!!
The parts truck I pulled my brackets off had the support bars also so I snagged those also.
Anyone doing this swap may also want to look at an adjustable proportioning valve for the rear brake line and possibly a residual pressure valve (hopefully that is what they call it.)
A very nice contribution to the 1st Gen Forum! :waytogo:
Thanks!
:usaflag:
Will there still be an improvement in brake performance if I run disc/drums?
I would certainly assume so. You'd running a dual diaphram booster which will generate more pressure than a single will.
me i would or rerouted the brake lines on my 1972 3/4 ton there a mess like yours i'm going to have them pre bent so there out of the way so i can reach in and get to my dip stick to check my oil
AJ, do you know what the part number for your master cylinder alone is? Either that or what bore diameter it is?
Here's one from Napa --> LINK
The Napa site says the bore size is 1.125". Hope that helps.
my rear disc brakes are so bad i was considering going back to drum.... i may use your write up and convert to the 1 ton booster as well. Great write up.
Brakes are over rated anyway...all they do is slow you down.:haha:
Hmm, 1.125 sounds the same as my 1/2 ton mc. I'll have to do some more research before deciding to swap it. My truck stops pretty good for not having rear brakes this past year.:eek1:
I know for a fact you can just swap in the 1 ton booster with the 1/2 ton master. What booster are you running now?
I'm running a 1-ton booster, and not sure what master is, but it is identical to the supposedly 1/2 ton one that was originally on the truck. Mine might be toast so I'm pondering options for a new one.
I don't think so, they have the same part number at the stores.
