NorthWestFab
We are Proud to offer the best in underdrive technology to the CK5 crowd:
The Blackbox is an auxillary high (1:1) / low (2.72) gearbox, that is designed to fit between your current transmission/transfer case. This gives you a number of possible ratios:
Blackbox High - Transfer case low
BlackBox Low - Transfer Case High
BlackBox Low - Transfer case Low (multiplied together)
BlackBox High - Transfer Case High
In essence, adding the BlackBox to your current transfer case gives you FOUR speed/crawl selections for your transfer case.
I'm sure you CK5 boys know the advanatges adding gearing like this will provide - so let me get down to the raw specs:
This is the ONLY underdrive where the output shaft is directly fixed and supported by bearings at bolt ends. This means significantly more support for both the planetary gears and output shaft.
We machine the case bodys from solid 6061-T6 billet roundstock, which are then hard anodized for durability and corrosion resistance.
Our output shafts are 4340 through hardened alloy steel
Our gears are a 6 pinion planetary system, originally designed by New Venture Gear which rates the gearset to 5500ft-lbs of torque.
Our shift mechanism features adjustable detent pressure, and servicable shift fork pads.
The BlackBox uses a standard 6 bolt round pattern used by GM, Ford, Dodge and Jeep, and can also can be adapted to most applications.
The Blackbox also includes a cable shifter for high/low selection
The Total Black Box Kit Includes The Following:
1 Black Box Planetary Gear Unit 2.72:1 Ratio
1 Mounting Ring and Foot
1 Shifter Assembly (Cable)
12 Mounting Studs
2 Mounting Gaskets
Retail Price: $1599.00 USD
Please call us @ 250 248 6024 or email [email protected] for more information.
12 Mounting Studs
2 Mounting Gaskets
Sweet set up though... been wanting for quite some time..
