The C&C 14 Bolt Disk Bracket! Bolt on for $50!!!
Gravel Maker
Sacramento, CA
This ones a teaser, we will be releasing them next week, Got approval last week from our insurance company and we are making them now! They will also be bent and use all the standard stuff!
And yes, $50 will be the price! No pre-orders, watch the website & here for news.....And the CK510 discount is good for another 10% off the $50.....
how is this different from the standard 14bolt one? does it allow you to use a single wheel hub?
Its all in the offset......
Using the SRW hubs changes that dramatically and the flange for the C&C is far removed from the placement of the flange on the SRW axles, the difference is greater than 3.5" and changing hubs can't change that. For that application I would use our weld on bracket and $36 can't be beat for those, I can't really see any reason you would want to weld on a flange to make it removable:confused: Just doosen't make any sense to me, why would you ever have to remove the bracket after it is on? And the reason people buy most bolt on brackets is because they aren't welders.......
These are for the C&C axles with the DRW hubs, likely to be used mostly for tow rigs and rigs with big enough tires that the extra width of the DRW dosen't matter......
