I would focus on the issues causing the excessive side to side axle movement before adding a trackbar.I still don't believe a trackbar is necessary with a crossover setup on a square. However if you're running a 12" lift with 8" shackles I can imagine the problems that would cause.
For myself, I've never had an issue tracking down the highway or down a bumpy road without a trackbar or hydro assist with lockers front and rear (not that it matters).
Furthermore, your experiences with a ford are not surprising, they built the truck with a trackbar after all right?
Truck is an 86m1028 (k30)
Frt suspension
New 6in springs HD (high spring rate)
New spring bushings
New ord fush kit
New ord shackles
All greaseable
New ord extended frt brake lines
Rebuilt ported psc box 2wd
Ord bolt on steering brace
New pitman arm (from ord)
New ord crossover steering
New ord high steer
Frt axle Dana 60
Ord big block engine crossmember
Ord motor mounts
Engine (shouldn't matter) mpfi 350
Condition = very sloppy steering
Box is tight, all ends are tight
Truck "squirms" when any steering corrections are made !
This is a very mild built "mall crawler"
I am NOT after a lot of flex, I'm actually looking for a nice firm ride (no sway)
Mostly street some mild wheeling & dare I say a little mud.
Rear suspension (if it matters)
New ord extended brake hose
New 2 & 1/2in lift 56's
New 4in ord shackle flip
New ord zero rate 1in back to center rear axle in wheel well.
Again condition is VERY sloppy steering.
I'm open to suggestions.
I don't claim to know it all or a lot for that matter, I just want my truck to steer nice.
Edit: forgot to mention frt wheel hub bearings are good (no slop).
And to the mods since I have highly hijacked this thread would someone please move this to the appropriate section ?
