the dana 44
mdm365
mineral wells wv
So I had to do the rear end a month or so ago now its the front I have a tooth missing off a spider gear and it was bouncing around the ring and pinion chipped a few teeth of the ring gear ect. It gouged up some of the carrier also.Dammmm:mad: can't seem to be able to do the stuff I been wanting to do on this thing something else fall apart although I can't seem to let it go------ Another flippen addiction :D
So I will need a carrier and a set of gears so my first question.IIRC the dana 44 is a 30 spline?? The second one is I am under the impression that there is some with different size bearings in these front ends?
I have a 1977 k5 the gear set has a date of 09/26/1976 ome spicer 45/11 and 4.07 what gives here the tag on the front end marked 45/11 4.09.
Good thing though is I don't have to deal with a crush sleeve this time:D
Any recommendations for the parts?
Mike
pm me on a deal . :D
and its the spindles that need the diffrent bearings on the dana 44 around 76-77 back or forth.
