the full convertable conversion
blazin_blazer
central arkansas
you guys replace the rockers w/2x3 tubing, i want to keep the inner & outter rockers...can i put a piece of 2x3 or 4'' channel..between the front tub mount and mount behind door, inside of original rockers up against bottom of floor and get the same support as replacing the original rocker w/tubing?
