The GAC Truck
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    12,102
    1,302
    New Hampshire
    Build(s):
    3
    More progress on the TBI swap:
    Unfortunately, I think the ECM might be toast. It isn't activating the fuel pump relay. I have verified the fuel pump and wiring works with the red jumper connector at the relay, I can also jumper out the oil pressure sensor connector and get the pump the run.
    Even with the relay jumpered out, it still won't fire the injectors. I can get it to run with starting fluid so I know I have spark but no fuel pump or injectors firing... I'm thinking ECM, thoughts?
  2. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    19,460
    3,360
    Lincoln, CA
    Build(s):
    5
    I would be inclined to think so
    Chevy305 likes this.
  3. Chevy305
    Jan 23, 2006
    12,102
    1,302
    New Hampshire
    Build(s):
    3
    It runs!!!!!!
    Turns out I missed a splice in the harness and the ECM wasn't seeing ignition 12v+ signal. Fixed the splice and it fired right up!
    I just need to get a proper throttle bracket and install the O2 sensor and I can be driving down the road.
    Next summer I'll actually swap in the ESC distributor. I'll plow this season as fuel only TBI.
    78K30, Big Ray, max 02 and 1 other person like this.
  4. Chevy305
    Jan 23, 2006
    12,102
    1,302
    New Hampshire
    Build(s):
    3
    More progress! Got a bunch of odds and ends wrapped up like the O2 sensor, throttle bracket, and wiring wrapped up.
    I drove it to the gas station and it runs and drives great! Idle is more stable and I picked up some more mid range power. It's not as smooth as a factory TBI truck but I didn't expect it to be with the carb intake, adapter, HEI distributor, and the cam isn't the same as the TBI ones. However, I will say it's better than the Holley and the Qjet I had on there especially during cold start and warm up.
    The only weird thing is the idle is a little low when warm. So I just looked up the procedure to set the idle so I'll do that when I get the time after the snow storm tonight and tomorrow.
    I'm very happy that she's ready to go:
    max 02, KirsL, Truckman4life and 4 others like this.
  5. Smokinthehippies
    Smokinthehippies 3/4 ton status Premium Member GMOTM Winner
    May 6, 2009
    8,229
    2,629
    Millard, NE
    Build(s):
    Nothing like a Sunday evening book report. Got her finished up the day before the snow lol.
    Good job though. I bet it will keep pulling its weight great.
  6. 79rustyk10
    79rustyk10 3/4 ton status Premium Member
    Sep 21, 2008
    6,622
    865
    Bikini Atol
    I have a TBI intake, and cam that will be coming out soon if you want. Free to a good home, or bad home, or whatever.
  7. Chevy305
    Jan 23, 2006
    12,102
    1,302
    New Hampshire
    Build(s):
    3
    Thanks but I have a TBI intake for it on my work bench. I threw an adapter on it because it was easier than swapping the intake... Lol
    On a side note, the GAC truck plowed flawlessly today. :woot:
  8. Chevy305
    Jan 23, 2006
    12,102
    1,302
    New Hampshire
    Build(s):
    3
