The mystery plugs of my K5
badmix
West Virginia
I have 2 plugs, both hand out just behind the distributer. One is a 4 prong with weatherpak connections and one is a 2 prong plug that is Bright RED to Orangish..
I had a quarajet carb but yanked that off to put a holley on, at the same time I installed a Mallory distributer. Im guessing these 2 plugs were what was left over from the swap.
Any ideas?? someone got schematic for electrical to the quadrajet or the OEM Dizzy?
what did they do? And why dont I need them now. :D
The 4 prong controlled the factory HEI distributor that was ECM controlled spark advance, the 2 prong was for the mixture control solenoid in the Q-jet carb.
You no longer need them because you changed both the carb and dizzy.
