so I have known of this trailer since around 1996ish . it has been sitting since before i learned of it then .
10 or so years ago he moved it to other farm land he used and put a portable food freezer on it and tarped it . well he never used it and the tarp rotted away and now the freezer unit is junk . ( got to get it over to farm for him to scrap it )
so what i have is a 18ft flatbed gooseneck trailer . the main beams for the frame are 12" tall x 4" wide . WOW !
it has home made or early production axles of some kind under it . there what looks to be ford 1ton full floater rear ends cut from the centers and a tube slid over them and welded up . the tube has a filler hole / plug in the middle also . i thinking ford by the style of backing plate looks bendix brake like i use to do a lot of work on .
the brakes are vac/hydro setup ? ? ? ha ha ha . that's going and swaping to a bendix electric/hydro unit .
then tires are 12-16.5 old stuff and looks to be my best bet is 235/75/17.5 conversion up to over the old . this gets me a 31" tire and 6k lbs per tire weight .
then blast / paint the old girl to make here look new again .
last will be a rewire and new lights .
the best part of the whole trailer ............ its all ready to be a dump just needs the ram/pump unit . its already hinged at the back .
will get better pics soon .
few for now . used friends truck to drag it out and home .
Of coarse that was twenty plus years ago and I'm sure tech has improved since then.
