The new updated Chalet ?
That will flip over even sitting still in some of the high wind gusts we get here...!..unless Prius batteries weigh 1500 lbs or something..
Driving range must be reduced a lot hauling that fiberglass cocoon around and all the other accessories..better camp close to home or a charging station...
Figure out how to economically put a Prius (or other EV) battery into a real RV or camper, coupled with some solar panels if you wanted to be out for awhile without moving, and you'd likely eliminate the need for a generator. Being able to run a microwave and/or coffeepot off the batteries without worry about drain, would be pretty nice.
There's a few full-time RVers on youtube that have used a "section" of an old Tesla battery to power their RVs. From what I've seen it seems to work pretty good.
I saw a Prius at a salvage yard being taken apart a few months ago--I was with someone ,just went for the ride when they picked up a part,so I couldn't hang around and watch the guy remove the battery--he started explaining how its made up of many batteries wired together and its voltage ranges between 200 and 300 volts depending on the age and model of the car...:eek1:
I looked up the weight of the Prius battery and it states 180 lbs..
They also have a 12V absorbed glass mat battery like a regular car that runs all the 12V stuff..
I never saw a Prius up close or looked at one to see how they are designed...and they have been around since 1997..I'm a slow learner I guess..:screwy:
