so this has been a little project i have been working on and then on hold as i got frustrated last fall and let it sit till this past week .
here end use will be for farm / woods / field use on my buddys 97 acres of land . so its built for off-road use only . no lights / suspension / or other things needed for road use .
1 used rusty / beat up / broken sub frame / ripped off LR hinge / frozen lower tailgate dogs / 10ft dump bed from a k3500 99-06 body style truck . the shop that had this installed a whole new dump bed and was ready to scrap this out . i scored it for less than the price of the working pump unit if you purchased one new .
the newer dump box's are a formed heavy tin box for the main rails and they hold crap / water / junk and rust out bad at the back end with no drain holes . so this let the hinge tear off 1 day when they were dumping a load of scrap metal from there shop .
here she is as i drug it home on a rollback when i was still towing .
it in for good . then i hooked it up to the truck and hit the button i had to stop before it was maxed out as it was ready to shove a shop light up in to the shop attic at 12ft height .
you can see them led backup light in the bright mid day sun on my truck .
