Yeah, I guess re-doing stuff does constitute progress.
Since I am in the re-doing mood, I figured I replace my turbo oil feed line. I made it out of regular braided steel line with aluminum fittings when I built it a couple years ago. I have had no problems with it, but it has a temp rating of around 275*F (IIRC) and a very finite service life (especially when it is used way beyond its rated temperature or pressure ratings). I decided that since it sits mere inches away from a component that can best its highest temperature rating by 1000*F it would probably be a good idea to remake it in the Teflon braided line that I should have used from the get-go (also the same material Cummins uses from the factory)
Here is what I had made originally:
I made a new line with the Teflon lined braided line. I used steel ends instead of aluminum as they are stronger and have a higher temperature rating than the aluminum fittings. I do miss the contrast and/or bling of the red and blue aluminum AN fittings though.
Here it is installed. Boring in comparison to the snazzy, super-pimp colored fittings, but more suited to the longevity I hope to acheive from this thing. I need to get back to the fitting store and see if they have gotten the steel adapters in to replace the red aluminum ones.
Hopefully soon I will be able to get back to the regularly scheduled programming of boring travel photos. Backcountry travel > service work.
