The Story Of A Cummins Suburban (Lots Of Pics)
Some time it takes me a while to read your new posts...I see them come up but save looking at them until I got time to really have a good look at the pictures on my computer.
Always worth the wait! :bow:
Very cool man! I like it.
Thanks!!
Thanks!! I'm glad I didn't disappoint you!! Would hate for you to wait that long to look at it on a computer and have it be a dud.
Nice write up, that tunnel is impressive.
Thanks. It's even more impressive in person. :whistle:
The Horton bring discontinue, what is the deal for late model dodges using a similar set up. Is it adaptable to the early dodges?
http://www.ebay.com/itm/Dodge-Ram-T...par-/220679384341?hash=item3361842d15&vxp=mtr
I recall looking into those when I was searching for a Horton. IIRC, (and it has been many years since I looked), those mount to a right-hand threaded hub (5.9L are LH thread) and are pulse-width modulated with a signal from the ECM. I could be wrong on the PWM aspect, but I don't think I am. It is not on or off, the ECM modulates the pulse-width of the signal to engage it only as much as is necessary to keep the motor cool. I believe the GM ones are PWM as well.
I really like the wandering stories. I like doing that in the mountains and foothills here. But I don't get to do it nearly enough.
Thanks!! Yeah, these are often the best times, where a loose plan is achieved but what happens from there is a big unknown.
At the beginning of August last year, we headed up to the car show at Watson Lake (the show we typically enter the Suburban into solely for the preferred parking). We passed on entering the Suburban this year and it worked out ok as we found some pretty sweet rides out in the parking area.
This old Napco was my favorite of the day:
Inside the show there was a cool old sedan setup in old-school camp fashion:
Behind the plywood is a tiny wood stove for heat:
Proof you don't need all of the latest and greatest technology to have a good time.
We wandered around the show, saw a bunch of neat stuff in the cool weather, then decided to head for home. On the way back we took a turn off the highway for no reason and did a little wandering around back in the hills. We had no destination in mind, just seeing what we could see. We ended up finding an old cemetery:
The old fencing around it was really ornate. Nothing like it would be today. The fence posts had some really neat tensioning devices on it:
Never seen anything like it before.
Wandering along following some old maps that could have used a healthy dose of updating we followed what we believed to be a road that would lead us out of where we were. We came to an area that had washed out pretty bad. After walking ahead and determining it kind of resembled what was on the map, we decided to press on. The washout crossed the trail at an odd angle:
Dropping in:
We got through that ok and just a little further down the trail we came across another area that washed out. It didn't look like much, but did flex the truck out a little going across it.
Then came one of my favorite pictures of the truck:
After we got out of that area we did some wandering around in a different area. Not much to post pictures of, but I did see a really neat rock in an undisclosed location:
So for having no plans to run trails on our journey, we ended up having a great day. Not knowing exactly where we were definitely added to the adventure of the whole thing. Good times!!
This run was the next weekend from the last one. I had been having problems with my navigation computer, one specific map program and my buddy Lance had done a bunch of work on it trying to get it to work right, but there was only one way to find out if it was working correctly--take it for a drive.
We settled on a trail I had seen recently. Now, once upon a time, long, long ago, before roads connected all of the little towns in the Bradshaw mountains, ore from the mines and supplies from the bigger towns were transported by mule teams. Hauling ore in this fashion is extremely expensive. If mineral prices drop below a fairly high price, mining becomes unprofitable. Much like the situation mentioned in previous posts regarding Jerome, a railroad was needed. A railroad through this area would be quite a feat of engineering and labor. The railroad would start out of Prescott and end up in Crown King. For years I wondered how a railroad ended up in Crown King starting from Prescott. Now much of the road that we drive on to get to Crown King is old railroad grade, but I could not figure out how it got down into the valley. I finally found an old hand drawn map that showed the route that the railroad took. I couldn't plot the map onto a current map, but with a bunch of time on Google Earth, I was able to locate pieces of where it ran and how it was routed. Some of it was visibly still drivable. Much of it is not however. A bunch of the old rail grade parallels highway 69 from Dewey/Humboldt to Prescott and is visible from the road where there are fills that crossed low areas and cuts through hills. Another area that can be found but not driven is near Blue Belle Mine. Some mining operations have restarted at the mine and a locked gate blocks the road to the mine. This was a neat setup. The ore came out of the mine area on a tramway and was dumped into ore bins at the railroad siding. Here the train would be loaded to take the ore to the mill. The tramway was over a mile long. I have heard the upper end of the tramway was still standing, but I can not determine for sure since the road is now closed. The railroad siding is long gone as are the bins and tramway. A little further down the line, the grade passes through private property and down beyond that finally comes out onto public land. This is where we set out to.
This was basically a research run to see what could actually be driven and how far we could go because the satellite imagery on Google Earth only goes so far. We set out, Lance, my boy and I in the Suburban and Lance's youngest son running point on a dirtbike. He and Lance had a real neat communication device between his helmet and Lance's phone. It was Bluetooth so it worked even when we had no cell coverage. Having him running point was very cool as he would call and tell us what he was seeing and not to go this way or that.
So we set out and got on the trail.
Washout on a filled low area that Lance's son called out:
There was a bypass to the raised area that we took to bypass the washout:
Last summer was fairly damp and we were surprised to see the cattle tanks (AKA ponds in other parts of the country) actually had a fair bit of water in them:
I don't think I'd like to be hiking along and come over this hill and have to navigate down through all of this cacti:
We came to a point, next to a tank, where the trail kind of stopped. It was obvious the railroad grade continued on ahead so Lance took off to wee where it went:
Looking back up from the way we came down the hill:
A little further down the hill:
Gigantic conglomerate rock along the way:
The railroad looped around down the hill we hiked down looped around and ended up way down below where we were. It is visible down along the side of the canyon way below where we are:
Unfortunately, this is where our journey on the railroad ends. More research will have to be done to see if the lower area can be accessed from somewhere down below. We ended up wandering back via a different route than we entered. We had a good time and learned a fair bit about the old railroad and the route it took. Hopefully I will be able to continue the story of this railroad at some point when I learn some more about the area.
i need to start doing more exploring like you guys do. there is a ton of mining history in southern NV as well, i should do some research.
