So for whatever reason my K5 won’t fit in the garage. I’m not sure if it was the angle of the driveway on our old home and this driveway being flat.... Either way my truck has to be parked outside or I switch to 35" tires down the road that should, I think give me the clearance I need.
Garage height is the same as my previous home or my wife just freaked out as I pulled close and just said the truck is to high. Anyway.....
So I’m thinking just removing the battery when it’s parked for now. I can park in the driveway and just park one of my other vehicles behind it. But I have a gravel area next to the drive way that can work unless the HOA balks at that idea. I did see others around here with boats etc parked in the same spot.
I assume a kill switch can be installed but until I can do that.... any suggestions?
Can I let air out of the tires?
. Air down, have the wife pull it in and you watch.
is part of home ownership
