these lines work on a 87 k30??
under application it's1/2 ton only. i think the thru hole size is the only difference on the caliper side.
application is for 79 & up ,so if your axles are 79 & up , they will work as both the 10 bolt & Dana 60 use the same 10mm banjo bolt
78 & down used the 7/16 banjo bolt.
really? thought the pro comp was made by earl or some well known company like that
I had a set of Pro Comp lines on mine and never had any issues. I didn't run them long though because they were to short when flexing.
