thick caked on grease... what to use? sand? eazy-off doesnt work
I've had great luck with a diesel fired hot water pressure washer. Since not everybody has access to one (I got lucky as a local farmer has one for washing his equipment and truck and I have pulled him out of ditches so I get free use), a scrub brush, degreaser, and a regular pressure washer will work. For those that don't have access to that, a garden hose with a spray nozzle will work. Each type has it's own level of "elbow grease". The garden hose method will require much more manual scrubbing to remove the heavy grease. The best thing to do is scrub/scrape as much off manually as you can, then soak in degreaser followed up by spraying with the hose. It may take several repeat cycles to get into the nooks and crannies. If you want to paint when you are done, brake cleaner works well for final degreasing/prep. I'm also one that buys it by the case as it has several applications (cleaning brakes, degreasing before paint, wasp/hornet killer, etc.).
To add to everyone else's opinions...
I deal with caked-on dirt, grease, cement, and burnt gear oil ALL DAY LONG at work (I work on heavy truck transmissions). If you don't have access to a steam cleaner or a hot-water pressure washer, you gotta scrape most of the thick crud off before chemicals will do much good. You can use chemicals and scraping together to remove the gunk in layers, but when the crap's that thick, it takes industrial power to hope for a one-shot cleanup. Hell, even our "cooker" needs 2 passes to get a really dirty transmission or axle clean enough to repaint, and that's a tractor-trailer-sized machine with 1.5 million BTU's of hot cleaning power!
Brakeclean is good stuff, but IMO it evaporates too fast for cleaning really heavy deposits. Safety-Kleen solvent works great since it doesn't evaporate fast; it stays "in" the crud to break up the grease that binds the buildup together. Kerosene does about the same, but isn't as safe.
IMO, using gasoline is just begging for the Fickle Finger of Fate to flick some third-degree burns your way, fire extinguisher or not. You can use it if you want... but I wouldn't.
