Think i found emission problem
dheavychevy38
Algonquin,illinois
I think i found my problem:grin: Before the truck was running to rich and i have gone through all the steps to figure it out everything is in good working order so i went out to double check everything and when ii removed the stock air cleaner i found that the air door inside is fubared and stuck closed.I am pretty sure that is what is causeing the to rich situation. So i oreder a msd coil cap and rotor and bumped the timeing 3 degrees advanced and am goin to take that plate out and try it again.:hack: :grind: :weld: :whistle:
I had the same problem on a 79 C10 305. 2 mechanics misdiagnosed it as an intake leak.
It will run a liitle choppy when cold with the air door jammed open but it warms up and smoothes out pretty quick. You can always get the replacement actuator parts for the stock air cleaner from LMC Truck.
