was rushing and not thinking putting new plugs in. forgot to mark the wires. to top it off i just pulled them all off. it a sbc. so how do i make this right again.
Firing order is 1-8-4-3-6-5-7-2 in a clockwise rotation. Pull the distributor cap and crank it over until you find TDC of the compression stroke. Now where ever the rotor is pointing is where the number 1 wire goes then continue with the firing order.
