so last weekend i changed my oil pan gasket got everything bolted up, put the oil filter on then i went to put the inspection cover back on i noticed there wasnt any room for the bar that connects the inspection cover to move past the oil filter. so instead of unbolting the brace i removed the new oil filter, bolted the brace back in place, then put the oil filter back on. but now my oil filter is leaking, it dosent look like its leaking from the oil filter adapter at the motor it looks like its leaking from the oil filter its self. now for my questions should i get another oil filter or just leave it till my next oil change. or can i change out the filter without draining all my new oil out? how much oil will i loose if i try to switch the filter out with out draining the pan.
thanks
isaac
thanks
isaac
