I'm thinking about swapping a 4L80E into my ’89 K5 (currently 700R4). Looking for feedback before I start parts-hunting.
Truck / Use Case
My 4L80E Swap Checklist — please sanity-check this
Transmission / Drivetrain Parts
VSS
Driveshaft / Angle Stuff
Gear Ratio Note
Questions for the CK5 experts
If I’m missing something obvious, feel free to roast me before I spend money.
Truck / Use Case
- ’89 K5, 4WD, 5.7 TBI
- 700R4 (rebuilt ~9k miles ago — TCC clutch already glazed + shuddering)
- Derale 17 row trans cooler (DER33604), temp gauge, AN-6 SS braided cooler lines
- NP241C (rebuilt 9k miles ago)
- 33×12.5 KO2s (<10k miles)
- 10-bolt axles w/new bearings & seals
- 4.10 gears just installed, <500 miles
- 2" lift, Bilstein shocks
- Driveshaft angles:
- T-case output: –5.1°
- Rear pinion: +6.1°
- Rear shaft: +19.6°
- Purpose: long highway trips in FL + towing a <3,000 lb Casita for 100s–1000s of miles
- Mall crawler until the kids get older
- 4L80E built with the correct 4WD output shaft (mandatory)
- 32-spline NP241C input gear *or* full 4L80E→241 adapter kit
- Standalone controller (leaning US Shift)
- 4L80E dipstick & tube
- Cooler line adapters or custom -6AN lines (4L80E ports are further back)
- Shifter rod/bracket adjustment
- Move crossmember rearward (existing crossmember reused)
- Front driveshaft longer, rear shorter
- Possible floor/tunnel tapping near cooler line bosses
- Verify flexplate spacing & converter bolt pattern
- Verify starter alignment/engagement
- Simply tap existing TBI TPS sensor signal wire
- Use a T-fitting on an existing vacuum nipple and a second GM MAP sensor - only needed if the controller requires it
VSS
- Use the NP241 conversion kit from Walters Engineering and Performance: https://www.walterseandp.com/product-page/np241-electronic-vss-conversion-kit-r2
- I found this at ck5.com from @Larry: https://ck5.com/forums/threads/factory-squarebody-4l80e-shift-linkage-picture-request.344528/
- With the longer 4L80E + 2" lift, rear shaft angle gets steeper
MayWill need a SYE + double-Cardan rear shaftdepending on final angles- Front shaft length + slip travel needs to be checked too
Gear Ratio Note
- 700R4 1st = 3.06:1
- 4L80E 1st = 2.48:1
- I’m totally fine with this — towing reliability > off-the-line punch
- My understanding is the stock crossmember is reused — I just drill new holes to move it back. Correct?
- Do the common 4L80E→NP241 Adapter kits include:
- the adapter housing and
- the 32-spline input gear?
- Or does it vary by vendor?
- If I order a fresh 4L80E, can a shop like Monster or Certified just build it with the correct 4WD output shaft from the start?
- Given my lift + angles + the longer trans:
- Is a SYE + double-Cardan rear shaft basically mandatory?
- Anyone running the stock slip yoke with a 4L80E successfully?
- Any issues with front shaft clearance after the swap?
